メインコンテンツにスキップ
はじめに
Use this guide to remove the fan from your Optoma HD20.
パーツ
パーツは指定されていません。
  1. Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: 手順 1、 2の画像 1 Optoma HD20 Fan Replacement, Disassembling Optoma HD20 Cover: 手順 1、 2の画像 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Fan Replacement: 手順 2、 1の画像 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Fan Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Fan Replacement: 手順 4、 1の画像 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Fan Replacement, Fan: 手順 5、 1の画像 1
    • Peel off the tape that is holding the metal casing down.
  6. Optoma HD20 Fan Replacement: 手順 6、 2の画像 1 Optoma HD20 Fan Replacement: 手順 6、 2の画像 2
    • Use a Phillips #1 screwdriver to unscrew the nine 4.5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the three 2.5 mm screws. This will allow you to remove the metal casing.
  7. Optoma HD20 Fan Replacement: 手順 7、 1の画像 1
    • Remove the metal casing by lifting it up off of the circuit board.
  8. Optoma HD20 Fan Replacement: 手順 8、 1の画像 1
    • Unplug the six wires stemming from the circuit board.
  9. Optoma HD20 Fan Replacement: 手順 9、 1の画像 1
    • Use a Philips #1 screwdriver to remove the four 4.5 mm screws
  10. Optoma HD20 Fan Replacement: 手順 10、 1の画像 1
    • Remove the three 4.5 mm screws using the Philips #1 screwdriver.
  11. Optoma HD20 Fan Replacement: 手順 11、 1の画像 1
    • Remove the two 4.5 mm screws located on either side of the VGA/SCART port using a 5 mm nut driver. This will further release the plastic backing from the motherboard.
  12. Optoma HD20 Fan Replacement: 手順 12、 1の画像 1
    • Slightly rotate the motherboard clockwise. This will prevent ports from getting caught on the plastic backing.
    • Lift the plastic backing to remove it.
  13. Optoma HD20 Fan Replacement: 手順 13、 1の画像 1
    • Ensure all screws are removed
    • Lift up the motherboard and take out the metal container beneath it.
    • Do this very carefully as there is still one cable attached.
  14. Optoma HD20 Fan Replacement: 手順 14、 1の画像 1
    • Unplug the white connector underneath the right side of the circuit board.
    • To remove, pinch both sides of the connector and pull it away from the circuit board.
  15. Optoma HD20 Fan Replacement: 手順 15、 2の画像 1 Optoma HD20 Fan Replacement: 手順 15、 2の画像 2
    • Use a Phillips #1 screwdriver to remove four 5 mm screws. This will release the fan.
  16. Optoma HD20 Fan Replacement: 手順 16、 2の画像 1 Optoma HD20 Fan Replacement: 手順 16、 2の画像 2
    • Pull the fan away from the metal housing unit.
    • Gently lift the fan up and out of the device. The fan is now removed.
終わりに
4 の人々がこのガイドを完成させました。
Trever
メンバー登録日: 2015年01月22日
1,205 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G23
4 メンバー
6のガイドは作成済み
6 件のコメント
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Graveyard Workshop - 返信
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Sterling Grogg - 返信
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
Gyrovague -
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
merrill277 - 返信
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
Mike Popov - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 27
過去 30 日: 109
今までの合計 11,150
