はじめに
Use this guide to remove the color wheel from your Optoma HD20.
必要な工具と部品
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
The black part is the clip that lifts up. Then gently tug on the cable.
The instructions are out of order here.
Wish I had read your comment before struggling with it for what seemed like hours.
Yes… Advice for when you go into this BEFORE consulting the internet and accidentally RIP it out?
I ripped the ribbon. Where can I find it’s replacement?
Use the plastic opening tool to remove the wiring.
Removing the white ribbon wire on mine required pushing out toward the ribbon a gray/brown piece that holds the ribbon in place. Once it is moved out, it slides out easily. No lifting needed, just pushing.
6 の人々がこのガイドを完成させました。
3 件のコメント
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter -
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
dlwalter -
The pictures don't really do justice to how hard it is to pop the focal cap off. One actually has to pull pretty hard, I was afraid of breaking something, but it all worked out.
eislerzoltan - 返信
you da best <3 ty for comment
Weyland Chiang - 返信
