はじめに
Use this guide to remove the air filter from your Optoma HD20.
必要な工具と部品
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
The black part is the clip that lifts up. Then gently tug on the cable.
The instructions are out of order here.
Wish I had read your comment before struggling with it for what seemed like hours.
Yes… Advice for when you go into this BEFORE consulting the internet and accidentally RIP it out?
I ripped the ribbon. Where can I find it’s replacement?
Carefully peel off each air filter from the device
Pull up on the air filter to remove it.
I did not see at least one filter in my projector after opening it. is it normal?
ある他の人がこのガイドを完成しました。
The pictures don't really do justice to how hard it is to pop the focal cap off. One actually has to pull pretty hard, I was afraid of breaking something, but it all worked out.
eislerzoltan - 返信
you da best <3 ty for comment
Weyland Chiang - 返信
