メインコンテンツにスキップ
Oppo X9000 Speaker Drivers Replacement
必要な工具と部品
  1. Oppo X9000 Speaker Drivers Replacement, Removing the Back Cover: 手順 1、 2の画像 1 Oppo X9000 Speaker Drivers Replacement, Removing the Back Cover: 手順 1、 2の画像 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Speaker Drivers Replacement, Removing the Battery: 手順 2、 1の画像 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Speaker Drivers Replacement, Remove the Back Panel Screws: 手順 3、 2の画像 1 Oppo X9000 Speaker Drivers Replacement, Remove the Back Panel Screws: 手順 3、 2の画像 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Speaker Drivers Replacement, Remove the Rubber Stoppers: 手順 4、 2の画像 1 Oppo X9000 Speaker Drivers Replacement, Remove the Rubber Stoppers: 手順 4、 2の画像 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Speaker Drivers Replacement, Remove the Newly Exposed Screws: 手順 5、 1の画像 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Speaker Drivers Replacement, Lift off the Back Panel: 手順 6、 2の画像 1 Oppo X9000 Speaker Drivers Replacement, Lift off the Back Panel: 手順 6、 2の画像 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
  7. Oppo X9000 Speaker Drivers Replacement, Remove the Speaker Drivers: 手順 7、 2の画像 1 Oppo X9000 Speaker Drivers Replacement, Remove the Speaker Drivers: 手順 7、 2の画像 2
    • Using the flat end of the spudger, pry the speaker drivers off of the chassis.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Sara Dafoe
メンバー登録日: 10/14/14
354 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-45, Amido Fall 2014 Cal Poly, Team 4-45, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G45
5 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 862
