はじめに
If you want to access internal components such as the pump or the heater, you have to open the machine. This is shown here.
必要な工具と部品
Remove all attachments such as the water tank, pomace container, brew group and drip tray.
Remove all the coffee beans from the machine.
Slide the cup holder all the way down.
Start to pry off the molded part at the back seam, the catches gradually loosen with a loud crack.
It's a bit tricky to slide the cover over the steam valve knob, you need some strength to do it.
Under the bean container, you'll find the white magnetic contact (reed contact) for the bean container lid. Lift it up and drop it through the opening in the molding.
Lift up the cover.
16 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
6 件のコメント
Danke. Hat prima funktioniert.
Perfect immer schön positives Feedback zu bekommen
Jawoll! Freut mich! :-)
VauWeh -
