はじめに
This guide will help you open up your Oontz Angle 3 Ultra, which will allow you to work on its sensitive internals. To open up the speaker, you must remove the back panel to access the inner components of the device.
必要な工具と部品
Remove the two black rubber sheaths around the edges of the speaker.
Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
ある他の人がこのガイドを完成しました。
