はじめに
Use this guide to fix the button pins of your Onkyo TX-800 if they are crooked.
必要な工具と部品
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
もう少しです!
終わりに
