はじめに
This guide will walk you through how to remove the phone's screen, which includes the LCD panel and digitizer.
必要な工具と部品
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Insert a SIM card removal tool into the small hole located on the top right corner of the phone, just above the volume buttons.
Push the removal tool into the hole and the tray should pop out.
Remove the SIM tray from the phone.
There is absolutely no reason to remove the sim tray, we're not removing the motherboard.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
Press the suction cup to the back panel to secure it.
With the help of the suction cup, pull up on the panel to completely detach it from the device.
It can't be stressed enough to do this very carefully. I did it very carefully, but not carefully enough. Cracked a corner. Also not just the edges, there's extra adhesive on the lower 2-3 cm's of the back.
Another remark, get in between the black bezel and the back cover, this is a bit unclear on the first picture. Same goes for the front, get in between the bezel and the front assembly.
Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
Four (longer) PH000 screws
Three shorter PH000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
Check http://imgur.com/wqD9Dis. Orange circles are the smaller screws (3 out of 7 are smaller than the other 4).
On the battery, locate a clear tab. This will be used to pull the battery out.
Firmly grasp the clear tab and pull up and away from the phone to remove the battery.
Continue to pull slowly on the battery, until it is completely free from the phone.
Strictly speaking, you don't need to remove the battery at all. The connector to the front assembly is underneath the speaker assembly.
I agree it's nearly impossible to remove the battery without damaging it. Even a tiny little bending can lower the capacity. And if you heat it up too much to soften the glue it can explode. Also never use metal tools on the battery in case u break through the protection foil it won't catch fire.
The instructions on the pull tab itself are pretty clear and contradict what's said here!
"Tear from position 1, and then pull out the battery from position 2."
The battery sits in a kind of a black "vest", which is the thing glued to the phone (not the battery itself).
This vest can be "unbuttoned" from the top and bottom sides (position 1, visible on some of the previous pictures).
After that the battery would pop out with much less effort (there is some adhesive in the "vest", but it's much less robust).
What is being depicted here is quite dangerous and unnecessary, as it makes the battery bend heavily.
Once all of the components on the back of the phone have been removed (battery, SIM card, etc), prepare for a battle with your heat gun and "oven mitts".
Using your heat resistant glove to hold onto the phone, evenly heat the edges of the phone.
Spend about 15-20 seconds on a small section about 2 inches long to make sure that it is sufficiently hot to remove the adhesive
After sufficiently heating a section of the edge, use the jimmy tool and slide it between the glass screen and the aluminum bezel of the phone.
Proceed to gently slide the jimmy around the area that has been heated to remove the the screen from the adhesive.
Having heat resistant gloves are very important as the device will get very hot and will burn your fingers if you come into contact directly with the phone.
if only mobile outer display glass is break then it essential to change whole display or we can only change the glass
please reply fast
Ajay Shete - 返信
After removing the adhesive and the screen is now loose from the phone, you'll notice that it is still attached to the back through a connector.
On the back of the phone, unclip the connector to the screen located on the bottom right hand side of the phone using a plastic pry tool.
Now that the pin is disconnected, you will have to gently slip the connector through the hole in the back of the phone to free the entire screen.
Once the connector is slipped through the hole, the screen should be free from the phone for good.
You'll notice we're missing a step here, the removal of the speaker assembly.. Needed to get to the display connector. Remove all 8 screws. The bottom ones are a tad lager than the top 4 ones, so be sure you don't mix these up.
Also, once you have the front assembly loose, apply a bit of heat to the connector, so you can lift it up a bit. It will block the entry otherwise and you won't be able to pull the flatcable out.
43 の人々がこのガイドを完成させました。
19 件のコメント
Does anyone know where to get a screen for the opx?
i just ordered one from aliexpress.
anyone knows the best way to glue the screen back onto the x? 3M 2 sided tape 2mm thickness is ok?
thanks
Hi Kill,
Did u order the display and touch or just the display? and which web site did u order it from?
Aditi Mangal
I'm also interested! can you post a link of the site?!
My one plus x got fell from my hand. Now the display slowly getting fading away with blurriness. It's almost completely over the phone now :(
whats the options available now? and what will be the cost of display set for the replacement?
(addition) someone on the OPX forum tried to fix the cracked screen only and they said that the digitizer & screen are glued together, they broke the digitizer while trying to separate it. So they had to get the whole digitizer+screen assembly instead which was about $160.
the cheapest I can find now is this one http://www.ebay.com/itm/OEM-Full-LCD-Dis...
forum post: https://forums.oneplus.net/threads/onepl...
Oneplus X Front Outer Screen Glass?
I'm stuck on step 10 ...... my connector doesn't fit through the hole. Did you lift the ribbon connector for the screen and if so how?
Hello, my OnePlus X has a shattered glass. However, the touch is working just fine and so is the display. In this case, i need to replace only the front glass, right? Is separating just the glass an easy task or not? Im going to be ordering a glass front online and have a professional do the job. Is that a viable alternative? Please help.
Definitely not a good idea, go for the full display assembly. The digitizer is glued and separating it from the glass is close to impossible without damaging the former, even for professionals, and then you'd have to glue the new glass to the digitizer which isn't exactly easy either.
Where will I get the new LCD display for my OnePlus X, and how much does it costs??
hi Shubhajit, Aliexpress is the best source. Mine arrived in 20 days…
I have a one plus x. His screen is damaged. Please tell me his screen where available and which cost.thanks
I have found a good OnePlus X screen on eBay, but they are quite expensive, about $100, €85.
My glass is cracked. Touch and display are just fine. I found a touch+digitizer online. Can this procedure be [relatively] safely used to replace those but keeping the display?
It would be performed by a professional who had never worked on this model before.
Wouldn't like him to damage other components. He does a fine job with other phones.
My phone got wet. After a few days drying out it now boots. The display is fine but the time and date are incorrect and the digitiser is completely unresponsive so I can't get past the lock screen. Do I definitely need to replace it or is it possible that it is just a connector that needs cleaning/ drying or another could the failure of another component give these symptoms?
