はじめに
This guide will show you how to replace the rear-facing camera of the OnePlus X.
必要な工具と部品
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
Four (longer) PH000 screws
Three shorter PH000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
Locate the camera on the motherboard, near the top-left of the phone.
Using a plastic pry tool, gently unclip the cable from the motherboard.
After disconnecting the camera, use a pair of precision tweezers to lift the camera and remove it from the phone.
