メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
OnePlus One Battery Replacement
必要な工具と部品
  1. OnePlus One Battery Replacement, Battery: 手順 1、 3の画像 1 OnePlus One Battery Replacement, Battery: 手順 1、 3の画像 2 OnePlus One Battery Replacement, Battery: 手順 1、 3の画像 3
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
    FixBotに聞いてみる
    コメントを追加
  2. OnePlus One Battery Replacement: 手順 2、 3の画像 1 OnePlus One Battery Replacement: 手順 2、 3の画像 2 OnePlus One Battery Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
    FixBotに聞いてみる
    コメントを追加
  3. OnePlus One Battery Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
    FixBotに聞いてみる
    コメントを追加
  4. OnePlus One Battery Replacement: 手順 4、 3の画像 1 OnePlus One Battery Replacement: 手順 4、 3の画像 2 OnePlus One Battery Replacement: 手順 4、 3の画像 3
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
    FixBotに聞いてみる
    コメントを追加
  5. OnePlus One Battery Replacement: 手順 5、 3の画像 1 OnePlus One Battery Replacement: 手順 5、 3の画像 2 OnePlus One Battery Replacement: 手順 5、 3の画像 3
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
201 の人々がこのガイドを完成させました。
作成者
22人の作成者と共同で作成されました。
Javier Cruz
メンバー登録日: 09/22/14
2,292 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 3-3, Brown Fall 2014 USF Tampa, Team 3-3, Brown Fall 2014人のメンバー
USFT-BROWN-F14S3G3
3 メンバー
24のガイドは作成済み
36件のガイドコメント
The Apple iPhone sim ejector is not long enough to work on an OPO. A paper clip is a better option.
stephenacook - 返信 共有
There will be a compatible battery with one pin OnePlus
Gendarmetal Rock - 返信 共有
Successfully accomplished, thanks to your clear instructions. One note: the adhesive on my unit was applied in about a quarter inch strip along the right underside of the battery as you view it from the back. Peeling up the left side allowed me to reach and release the adhesive on the opposite side with the spudger or knife blade.
That Guy - 返信 共有
Thank you! I use a slim (but not sharp) butter knife to nudge the battery out slowly by poking the adhesive tape along its length. It was a bit unnerving because I was afraid of damaging the soft battery. Worked out in the end.
Benoit Hogue - 返信 共有
One note to add is that the original battery connector's top was glued to the motherboard cover. I had to remove the battery before I could successfully sepearte the 2. My phone is still working and I'm charging it right now! :)
Thanks for the very detailed guide.
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 47
過去 30 日: 217
今までの合計 221,797
