メインコンテンツにスキップ
OnePlus 6 or 6T Alert Slider Cleaning
必要な工具と部品
  1. OnePlus 6 or 6T Alert Slider Cleaning, The problem: 手順 1、 3の画像 1 OnePlus 6 or 6T Alert Slider Cleaning, The problem: 手順 1、 3の画像 2 OnePlus 6 or 6T Alert Slider Cleaning, The problem: 手順 1、 3の画像 3
    • Although the three distinct slider positions are set, the phone only recognizes two of them.
  2. OnePlus 6 or 6T Alert Slider Cleaning, Clean the slider: 手順 2、 2の画像 1 OnePlus 6 or 6T Alert Slider Cleaning, Clean the slider: 手順 2、 2の画像 2
    • Use a small tool to clean up the two different sides: the slider side and the top side.
    • Be careful not to scratch the side of the phone. A soft-tipped tool, like the iFixit spudger, is ideal.
  3. OnePlus 6 or 6T Alert Slider Cleaning, Clean the other sides as well!: 手順 3、 1の画像 1
    • Clean the other two sides as well to prevent the same issue from occurring.
終わりに
If you cannot remove more dust from the slider then it should be fixed. Try moving it to the other positions and feel whether the slider clicks into the positions. If the slider is still not functioning correctly, then perhaps a replacement of the slider is necessary. A replacement guide for the older OnePlus 5T can be found here.
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Martin Muller
メンバー登録日: 02/24/21
231 ポイント
1ガイドが承認済み
1件のガイドコメント
Thank you boss. you are a lifesaver !!! Just now did it. I have been troubled by this for more than a year.. Now it's working good as new.. Thanks a lot !!
Mahesh Lal - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 29
今までの合計 3,490
