メインコンテンツにスキップ
OnePlus 5 Speaker Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. OnePlus 5 Speaker Replacement, Back Panel Replacement: 手順 1、 1の画像 1
    • Always make sure to turn off the phone before attempting to replace a part.
    • Power off the phone by holding down the rectangular power button on right side and pressing the red button that says "Power off."
  2. OnePlus 5 Speaker Replacement: 手順 2、 2の画像 1 OnePlus 5 Speaker Replacement: 手順 2、 2の画像 2
    • Remove the two 1mm Torx #2 screws at the bottom of the phone by rotating the screwdriver counter-clockwise.
  3. OnePlus 5 Speaker Replacement: 手順 3、 3の画像 1 OnePlus 5 Speaker Replacement: 手順 3、 3の画像 2 OnePlus 5 Speaker Replacement: 手順 3、 3の画像 3
    • Locate the sim card on the right side of the phone.
    • Insert the SIM ejector screwdriver bit into the hole left of the sim card holder by applying pressure.
    • It is also okay to use the SIM card eject tool for this step.
    • Remove the sim card holder by pulling it out with your fingers.
  4. OnePlus 5 Speaker Replacement: 手順 4、 3の画像 1 OnePlus 5 Speaker Replacement: 手順 4、 3の画像 2 OnePlus 5 Speaker Replacement: 手順 4、 3の画像 3
    • Insert the plastic iFixit opening tool between the the plastic rim of the screen and the metal edge of the phone.
    • Place a suction cup on the screen to gain more leverage when separating the screen from the back plate.
    • Moving right to left around the phone, carefully pry the screen away from the back plate by wiggling the iFixit opening tool and pulling the suction cup in the opposite direction.
    • When reassembling, apply pressure to the edges of the screen and back plate together until they pop back into place.
  5. OnePlus 5 Speaker Replacement: 手順 5、 3の画像 1 OnePlus 5 Speaker Replacement: 手順 5、 3の画像 2 OnePlus 5 Speaker Replacement: 手順 5、 3の画像 3
    • Locate the metal connector cap on the upper half of the device directly above the battery.
    • Remove the 1mm Phillips #0 screw from the metal connector cap by rotating the screwdriver counter-clockwise.
  6. OnePlus 5 Speaker Replacement: 手順 6、 2の画像 1 OnePlus 5 Speaker Replacement: 手順 6、 2の画像 2
    • Carefully pop out the metal connector cap with the nylon spudger and remove it by pulling up.
  7. OnePlus 5 Speaker Replacement: 手順 7、 3の画像 1 OnePlus 5 Speaker Replacement: 手順 7、 3の画像 2 OnePlus 5 Speaker Replacement: 手順 7、 3の画像 3
    • Locate the two connectors directly above the battery on the left side of the device.
    • Remove the battery connector cable located to the right of the charging port connector cable using a nylon spudger by prying underneath it and popping it up.
    • Remove the charging port connector cable to the left of the battery cable using a nylon spudger by prying underneath it and popping it up.
  8. OnePlus 5 Speaker Replacement, Loudspeaker: 手順 8、 3の画像 1 OnePlus 5 Speaker Replacement, Loudspeaker: 手順 8、 3の画像 2 OnePlus 5 Speaker Replacement, Loudspeaker: 手順 8、 3の画像 3
    • Remove the six 1mm Phillips #0 screws by rotating the screwdriver counter-clockwise.
  9. OnePlus 5 Speaker Replacement: 手順 9、 3の画像 1 OnePlus 5 Speaker Replacement: 手順 9、 3の画像 2 OnePlus 5 Speaker Replacement: 手順 9、 3の画像 3
    • Remove the loudspeaker by gently pushing the spudger underneath it and prying it out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Jose Velazquez
メンバー登録日: 01/24/18
866 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S19-G1, Livingston Winter 2018 Cal Poly, Team S19-G1, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S19G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 10
今までの合計 511
