メインコンテンツにスキップ
OneLink Safe and Sound Speaker Replacement
必要な工具と部品
  1. OneLink Safe and Sound Speaker Replacement, Cover: 手順 1、 2の画像 1 OneLink Safe and Sound Speaker Replacement, Cover: 手順 1、 2の画像 2
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Speaker Replacement: 手順 2、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 2、 2の画像 2
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Speaker Replacement: 手順 3、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Speaker Replacement: 手順 4、 1の画像 1
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Speaker Replacement: 手順 5、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 5、 2の画像 2
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Speaker Replacement, Battery: 手順 6、 1の画像 1
    • Use the plastic opening tool to disconnect the cable from the motherboard.
  7. OneLink Safe and Sound Speaker Replacement: 手順 7、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 7、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
  8. OneLink Safe and Sound Speaker Replacement: 手順 8、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 8、 2の画像 2
    • Remove the plastic cage holding the battery in place.
    • Remove the battery from the device.
  9. OneLink Safe and Sound Speaker Replacement, Bluetooth Module: 手順 9、 1の画像 1
    • Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
  10. OneLink Safe and Sound Speaker Replacement: 手順 10、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 10、 2の画像 2
    • Lift the Bluetooth module off of the daughterboard.
    • Lift it straight up to avoid bending the delicate pins that connect the Bluetooth module to the board.
  11. OneLink Safe and Sound Speaker Replacement, Motherboard: 手順 11、 3の画像 1 OneLink Safe and Sound Speaker Replacement, Motherboard: 手順 11、 3の画像 2 OneLink Safe and Sound Speaker Replacement, Motherboard: 手順 11、 3の画像 3
    • Use the opening tool to disconnect the speaker cables from the daughterboard.
    • Use the opening to lift the daughterboard off of the motherboard.
    • The daughterboard is sitting on a white plastic base on top of the motherboard.
  12. OneLink Safe and Sound Speaker Replacement: 手順 12、 2の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 12、 2の画像 2
    • Use a Phillips #0 screwdriver to remove seven screws securing the white base and motherboard.
  13. OneLink Safe and Sound Speaker Replacement: 手順 13、 3の画像 1 OneLink Safe and Sound Speaker Replacement: 手順 13、 3の画像 2 OneLink Safe and Sound Speaker Replacement: 手順 13、 3の画像 3
    • Gently remove the motherboard.
  14. OneLink Safe and Sound Speaker Replacement, Speaker: 手順 14、 2の画像 1 OneLink Safe and Sound Speaker Replacement, Speaker: 手順 14、 2の画像 2
    • Remove the speaker cables from the channels along the edge of the speaker cover.
    • Use an opening tool or your fingers to lift the speaker cover off of the back cover which houses the speakers.
  15. OneLink Safe and Sound Speaker Replacement: 手順 15、 1の画像 1
    • When the speaker cover is removed the speakers can be replaced.
終わりに
作成者
3人の作成者と共同で作成されました。
Arianna Roberts
メンバー登録日: 11/10/22
639 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 2-2, Petersen Fall 2022 UMass Dartmouth, Team 2-2, Petersen Fall 2022人のメンバー
UMASSD-PETERSEN-F22S2G2
3 メンバー
6のガイドは作成済み
コメント 1 件
I read in some review that the replacement speakers are 10 watts and they have a diameter of 6.8 inches. Can you add a picture of the actual speaker so I can purchase a replacement for my damaged OneLink Safe and Sound speaker?
BBQ 572 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 4
今までの合計 122
