メインコンテンツにスキップ
One Education Infinity:One Hinge Contact Assembly Replacement
必要な工具と部品
  1. One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: 手順 1、 2の画像 1 One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: 手順 1、 2の画像 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 2、 2の画像 1 One Education Infinity:One Hinge Contact Assembly Replacement: 手順 2、 2の画像 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 3、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 4、 2の画像 1 One Education Infinity:One Hinge Contact Assembly Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: 手順 5、 2の画像 1 One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: 手順 5、 2の画像 2
    • Lift the hinge away from the device.
  6. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 6、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the two 6.5mm screws.
  7. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 7、 2の画像 1 One Education Infinity:One Hinge Contact Assembly Replacement: 手順 7、 2の画像 2
    • Slide a Jimmy or other prying tool along the seam of the hinge to pry the casing apart.
  8. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 8、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the two 4.3mm screws holding the circuit board in place.
  9. One Education Infinity:One Hinge Contact Assembly Replacement: 手順 9、 1の画像 1
    • Use a spudger to pry the circuit board away from the casing.
    • Always use ESD safe tools when removing delicate components.
終わりに
作成者
2人の作成者と共同で作成されました。
Taylor Bratsch
メンバー登録日: 09/06/16
6,083 ポイント
14のガイドは作成済み
1件のガイドコメント
Everything is very detailed and shown. Everything is also done in detail on this site ++https://oceanessay.com/buy-thesis-pape... , which helps students learn. There you will find a lot of educational materials.
Nathan Joyce - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 295
