メインコンテンツにスキップ
One Education Infinity:One Daughterboard Replacement
必要な工具と部品
  1. One Education Infinity:One Daughterboard Replacement, Back Case: 手順 1、 2の画像 1 One Education Infinity:One Daughterboard Replacement, Back Case: 手順 1、 2の画像 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Daughterboard Replacement: 手順 2、 2の画像 1 One Education Infinity:One Daughterboard Replacement: 手順 2、 2の画像 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Daughterboard Replacement: 手順 3、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Daughterboard Replacement: 手順 4、 2の画像 1 One Education Infinity:One Daughterboard Replacement: 手順 4、 2の画像 2
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Daughterboard Replacement, Daughterboard: 手順 5、 2の画像 1 One Education Infinity:One Daughterboard Replacement, Daughterboard: 手順 5、 2の画像 2
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity:One Daughterboard Replacement: 手順 6、 2の画像 1 One Education Infinity:One Daughterboard Replacement: 手順 6、 2の画像 2
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Daughterboard Replacement: 手順 7、 3の画像 1 One Education Infinity:One Daughterboard Replacement: 手順 7、 3の画像 2 One Education Infinity:One Daughterboard Replacement: 手順 7、 3の画像 3
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
終わりに
作成者
1人の作成者と共同作成されました。
Taylor Bratsch
メンバー登録日: 09/06/16
5,747 ポイント
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 15
今までの合計 258
