はじめに
This guide will detail how to safely remove the motherboard from the One Education Infinity laptop. The model number for the Infinity is A03. This device can be recognized by its dark grey exterior, light grey interior, purple carrying handle, and rotating camera above the screen.
The Infinity was released in Spring 2019 and is NOT the same as the Infinity: One.
必要な工具と部品
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
