メインコンテンツにスキップ
One Education Infinity CMOS Battery Replacement
必要な工具と部品
  1. One Education Infinity CMOS Battery Replacement, Back Case: 手順 1、 3の画像 1 One Education Infinity CMOS Battery Replacement, Back Case: 手順 1、 3の画像 2 One Education Infinity CMOS Battery Replacement, Back Case: 手順 1、 3の画像 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity CMOS Battery Replacement: 手順 2、 2の画像 1 One Education Infinity CMOS Battery Replacement: 手順 2、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity CMOS Battery Replacement: 手順 3、 3の画像 1 One Education Infinity CMOS Battery Replacement: 手順 3、 3の画像 2 One Education Infinity CMOS Battery Replacement: 手順 3、 3の画像 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity CMOS Battery Replacement, Battery: 手順 4、 3の画像 1 One Education Infinity CMOS Battery Replacement, Battery: 手順 4、 3の画像 2 One Education Infinity CMOS Battery Replacement, Battery: 手順 4、 3の画像 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity CMOS Battery Replacement: 手順 5、 3の画像 1 One Education Infinity CMOS Battery Replacement: 手順 5、 3の画像 2 One Education Infinity CMOS Battery Replacement: 手順 5、 3の画像 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity CMOS Battery Replacement, CMOS Battery: 手順 6、 3の画像 1 One Education Infinity CMOS Battery Replacement, CMOS Battery: 手順 6、 3の画像 2 One Education Infinity CMOS Battery Replacement, CMOS Battery: 手順 6、 3の画像 3
    • Use a plastic spudger to slide out the cable connector attached to the CMOS battery from the motherboard.
  7. One Education Infinity CMOS Battery Replacement: 手順 7、 3の画像 1 One Education Infinity CMOS Battery Replacement: 手順 7、 3の画像 2 One Education Infinity CMOS Battery Replacement: 手順 7、 3の画像 3
    • Peel the CMOS battery gently from the back case, as there is a layer of light adhesive holding it down.
    • Remove the CMOS battery.
終わりに
作成者
1人の作成者と共同作成されました。
Austin Blakely
メンバー登録日: 03/11/19
19,628 ポイント
53のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
17,218のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 258
