はじめに
If you are going to replace any of the components in the One Education Infinity, you will need to remove the back case first. After removing the back case, remove the battery as a safety precaution to prevent the risk of electric shock as you work on your device (even if you are only replacing the display assembly).
必要な工具と部品
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
もう少しです!
終わりに
