メインコンテンツにスキップ
Onda V701 Front- Facing Camera Replacement
必要な工具と部品
  1. Onda V701 Front- Facing Camera Replacement, Back Panel: 手順 1、 3の画像 1 Onda V701 Front- Facing Camera Replacement, Back Panel: 手順 1、 3の画像 2 Onda V701 Front- Facing Camera Replacement, Back Panel: 手順 1、 3の画像 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Front- Facing Camera Replacement: 手順 2、 3の画像 1 Onda V701 Front- Facing Camera Replacement: 手順 2、 3の画像 2 Onda V701 Front- Facing Camera Replacement: 手順 2、 3の画像 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Front- Facing Camera Replacement: 手順 3、 2の画像 1 Onda V701 Front- Facing Camera Replacement: 手順 3、 2の画像 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Front- Facing Camera Replacement: 手順 4、 2の画像 1 Onda V701 Front- Facing Camera Replacement: 手順 4、 2の画像 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Front- Facing Camera Replacement: 手順 5、 3の画像 1 Onda V701 Front- Facing Camera Replacement: 手順 5、 3の画像 2 Onda V701 Front- Facing Camera Replacement: 手順 5、 3の画像 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: 手順 6、 2の画像 1 Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: 手順 6、 2の画像 2
    • Gently pry the front-facing camera away from the back panel using a spudger.
  7. Onda V701 Front- Facing Camera Replacement: 手順 7、 2の画像 1 Onda V701 Front- Facing Camera Replacement: 手順 7、 2の画像 2
    • Flip the gray locking tab of the ribbon connector up using a spudger.
    • Remove the ribbon cable from the connector.
  8. Onda V701 Front- Facing Camera Replacement: 手順 8、 1の画像 1
    • Remove the front-facing camera assembly.
終わりに
作成者
4人の作成者と共同で作成されました。
Bradley Huber
メンバー登録日: 03/11/15
366 ポイント
3のガイドは作成済み
チーム
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 241
