メインコンテンツにスキップ
Onda V701 Battery Replacement
必要な工具と部品
  1. Onda V701 Battery Replacement, Back Panel: 手順 1、 3の画像 1 Onda V701 Battery Replacement, Back Panel: 手順 1、 3の画像 2 Onda V701 Battery Replacement, Back Panel: 手順 1、 3の画像 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Battery Replacement: 手順 2、 3の画像 1 Onda V701 Battery Replacement: 手順 2、 3の画像 2 Onda V701 Battery Replacement: 手順 2、 3の画像 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Battery Replacement: 手順 3、 2の画像 1 Onda V701 Battery Replacement: 手順 3、 2の画像 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Battery Replacement: 手順 4、 2の画像 1 Onda V701 Battery Replacement: 手順 4、 2の画像 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Battery Replacement: 手順 5、 3の画像 1 Onda V701 Battery Replacement: 手順 5、 3の画像 2 Onda V701 Battery Replacement: 手順 5、 3の画像 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Battery Replacement, Battery: 手順 6、 1の画像 1
    • Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
    • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
  7. Onda V701 Battery Replacement: 手順 7、 3の画像 1 Onda V701 Battery Replacement: 手順 7、 3の画像 2 Onda V701 Battery Replacement: 手順 7、 3の画像 3
    • Carefully pry the battery away from the back panel using the nylon or metal spudger.
    • Gently remove the battery from the back panel.
    • Ensure not to excessively bend or puncture the battery. Doing so could cause the battery to catch on fire or explode.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Bradley Huber
メンバー登録日: 03/11/15
366 ポイント
3のガイドは作成済み
チーム
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S4G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 845
