メインコンテンツにスキップ
Omaker M4 Port Cover Replacement
必要な工具と部品
  1. Omaker M4 Port Cover Replacement, Back Case: 手順 1、 1の画像 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: 手順 2、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 2、 2の画像 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: 手順 3、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 3、 2の画像 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: 手順 4、 1の画像 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: 手順 5、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: 手順 6、 2の画像 1 Omaker M4 Port Cover Replacement, Motherboard: 手順 6、 2の画像 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: 手順 7、 1の画像 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: 手順 8、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 8、 2の画像 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: 手順 9、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 9、 2の画像 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: 手順 10、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 10、 2の画像 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: 手順 11、 2の画像 1 Omaker M4 Port Cover Replacement, Port Cover: 手順 11、 2の画像 2
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: 手順 12、 1の画像 1
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: 手順 13、 2の画像 1 Omaker M4 Port Cover Replacement: 手順 13、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: 手順 14、 1の画像 1
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Obaida Matar
メンバー登録日: 02/17/16
119 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016人のメンバー
USFT-SULLIVAN-S16S2G2
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 387
