メインコンテンツにスキップ
Omaker M4 Motherboard Replacement
必要な工具と部品
  1. Omaker M4 Motherboard Replacement, Back Case: 手順 1、 1の画像 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Motherboard Replacement: 手順 2、 2の画像 1 Omaker M4 Motherboard Replacement: 手順 2、 2の画像 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Motherboard Replacement: 手順 3、 2の画像 1 Omaker M4 Motherboard Replacement: 手順 3、 2の画像 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Motherboard Replacement: 手順 4、 1の画像 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Motherboard Replacement: 手順 5、 2の画像 1 Omaker M4 Motherboard Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Omaker M4 Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Motherboard Replacement: 手順 8、 2の画像 1 Omaker M4 Motherboard Replacement: 手順 8、 2の画像 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Motherboard Replacement: 手順 9、 2の画像 1 Omaker M4 Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Motherboard Replacement: 手順 10、 2の画像 1 Omaker M4 Motherboard Replacement: 手順 10、 2の画像 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
[deleted]
メンバー登録日: 02/17/16
679 ポイント
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 1,158
