メインコンテンツにスキップ
Olympus TG-820 iHS Locking Mechanism Replacement
必要な工具と部品
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: 手順 1、 1の画像 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: 手順 2、 3の画像 1 Olympus TG-820 iHS Locking Mechanism Replacement: 手順 2、 3の画像 2 Olympus TG-820 iHS Locking Mechanism Replacement: 手順 2、 3の画像 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: 手順 3、 2の画像 1 Olympus TG-820 iHS Locking Mechanism Replacement: 手順 3、 2の画像 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: 手順 4、 3の画像 1 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: 手順 4、 3の画像 2 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: 手順 4、 3の画像 3
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: 手順 5、 1の画像 1
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: 手順 6、 2の画像 1 Olympus TG-820 iHS Locking Mechanism Replacement: 手順 6、 2の画像 2
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
終わりに
作成者
2人の作成者と共同で作成されました。
Larissa Knight
メンバー登録日: 03/21/16
549 ポイント
5のガイドは作成済み
チーム
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016人のメンバー
CLEM-BENSON-S16S7G2
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 8
今までの合計 479
