はじめに
Is your lens out of line or need cleaning? This guide will show how to go about changing the lens.
必要な工具と部品
Orient the camera so you are looking at the bottom.
Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
Using the plastic opening tool, pry the black component out of the cameras casing.
The black component is connected to the motherboard using some ribbon cables, it is not necessary to disconnect these cables to replace the lens.
The black component will just fold out for access to the lens mechanism
Locate the three silver screws on the top of the lens, and remove them using the Phillips #000 screwdriver
Locate the two screws on the right side of the lens, and remove them with the Phillips #000 screwdriver.
After removing the screws, the lens will just lift free from the black component.
