メインコンテンツにスキップ
Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement
必要な工具と部品
  1. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Connector Port Casing: 手順 1、 1の画像 1
    • Locate the side of the camera with the connector cover.
    • Remove the 2 Phillips #00 4.6mm casing screws.
  2. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 2、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 2、 2の画像 2
    • Open the connector cover by sliding the tab labeled lock to revile orange.
    • Slide the connector cover lock to revile orange and the door will spring open.
    • Remove the single internal Phillips #00 3.77mm screw.
  3. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 3、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 3、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 3、 3の画像 3
    • Close the door to gain access to the casing.
    • Use your fingers to remove the black plastic casing that surrounds the connector door.
    • Use your fingers to remove the next black plastic piece .
    • Remove the two screws revealed
  4. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Strap Eyelet Casing: 手順 4、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Strap Eyelet Casing: 手順 4、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Strap Eyelet Casing: 手順 4、 3の画像 3
    • Locate the strap eyelet side of the camera and remove the 2 Phillips #00 5.3mm screws in the handle.
    • Using your fingers, take off the handle, the black casing underneath, and gently wiggle out the shiny black casing below that.
  5. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 5、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 5、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 5、 3の画像 3
    • On the bottom of the camera, remove the single Phillips #00 3.5mm screw from the casing below the grip.
    • Using a plastic opening tool, gently pry the Olympus grip up and remove it.
  6. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Front Case: 手順 6、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Front Case: 手順 6、 2の画像 2
    • Remove the red ring surrounding the lens by twisting it counter-clockwise
  7. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 7、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 7、 2の画像 2
    • Remove the 2 Phillips #00 3.4mm screws that secure the faceplate just reveled by the grip.
    • On the bottom of the camera, remove the single Phillips #00 3.4mm screw by the tripod socket securing the face plate.
  8. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 8、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 8、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 8、 3の画像 3
    • Use a plastic prying tool to lift and remove the faceplate .
    • There will be some resistance from a sticker just under the GPS logo.
    • The black plastic ring around the flash may fall as it is no longer secure.
  9. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Display Assembly: 手順 9、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Display Assembly: 手順 9、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Display Assembly: 手順 9、 3の画像 3
    • To detach the monitor screen, remove the following 7 screws:
    • Locate the flash and remove the 2 Phillips #00 9.23mm & 14.87mm screws.
    • Locate the battery door and remove the single Phillips #00 3.37mm screw.
    • On the bottom of the camera, remove the single Phillips 3.58mm screw near the tripod socket.
  10. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 10、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 10、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 10、 3の画像 3
    • On the face plate, locate and remove the 2 eyelet strap side Phillips #00 9.2mm corner screws and the lower battery corner Phillips #00 14.87mm screw.
    • Use your fingers to unclasp the casing clips on either side of the camera and pull down the monitor casing.
    • Using the spudger to gently pry the screen away from the body of the camera.
  11. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 11、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 11、 2の画像 2
    • Locate the clasp for the white ribbon.
    • Use the spudger to lift the clasp releasing the ribbon
  12. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 12、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 12、 2の画像 2
    • Locate the clasp for the orange ribbon in between the motherboard and lens box.
    • Use the spudger to lift the clasp releasing the ribbon.
  13. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 13、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 13、 2の画像 2
    • Next pry up on the white connector using the spudger to free the screen from the device.
    • The housing and monitor will be separated.
  14. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Back Panel & Buttons: 手順 14、 3の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Back Panel & Buttons: 手順 14、 3の画像 2 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement, Back Panel & Buttons: 手順 14、 3の画像 3
    • On the back of the separated monitor, remove the 10 silver Phillips #00 4.4mm screws and the 1 black Phillips #00 3.26mm screw.
    • Use your fingers to remove the small corner metal triangle.
    • Using the spudger on the edge of the screen to lift it and remove the metal insert.
  15. Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 15、 2の画像 1 Olympus Stylus Tough TG-2 iHS Back Panel & Buttons Replacement: 手順 15、 2の画像 2
    • Use your fingers to lift the green circuit board and buttons out of the case.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Amanda
メンバー登録日: 07/20/15
933 ポイント
8のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Carnegie Fall 2015 Eastern Washington University, Team 1-5, Carnegie Fall 2015人のメンバー
EWU-CARNEGIE-F15S1G5
3 メンバー
16のガイドは作成済み
コメント 1 件
Any advice on where to buy a replacement back panel for the TG-2?
epaulan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 9
今までの合計 2,060
