メインコンテンツにスキップ
Olympus Stylus Tough 6020 Lens Replacement
必要な工具と部品
  1. Olympus Stylus Tough 6020 Lens Replacement, Battery: 手順 1、 1の画像 1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: 手順 2、 3の画像 1 Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: 手順 2、 3の画像 2 Olympus Stylus Tough 6020 Lens Replacement, Bottom Plating: 手順 2、 3の画像 3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 Lens Replacement, Top Plating: 手順 3、 3の画像 1 Olympus Stylus Tough 6020 Lens Replacement, Top Plating: 手順 3、 3の画像 2 Olympus Stylus Tough 6020 Lens Replacement, Top Plating: 手順 3、 3の画像 3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 Lens Replacement, Left Plating: 手順 4、 2の画像 1 Olympus Stylus Tough 6020 Lens Replacement, Left Plating: 手順 4、 2の画像 2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: 手順 5、 3の画像 1 Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: 手順 5、 3の画像 2 Olympus Stylus Tough 6020 Lens Replacement, Black "Olympus" Face Plate: 手順 5、 3の画像 3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 Lens Replacement, End Casing: 手順 6、 3の画像 1 Olympus Stylus Tough 6020 Lens Replacement, End Casing: 手順 6、 3の画像 2 Olympus Stylus Tough 6020 Lens Replacement, End Casing: 手順 6、 3の画像 3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: 手順 7、 3の画像 1 Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: 手順 7、 3の画像 2 Olympus Stylus Tough 6020 Lens Replacement, Blue Face Plate: 手順 7、 3の画像 3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 Lens Replacement, Back Plate: 手順 8、 1の画像 1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 Lens Replacement: 手順 9、 3の画像 1 Olympus Stylus Tough 6020 Lens Replacement: 手順 9、 3の画像 2 Olympus Stylus Tough 6020 Lens Replacement: 手順 9、 3の画像 3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 Lens Replacement, Lens: 手順 10、 1の画像 1
    • Unscrew screws on place holder plates
  11. Olympus Stylus Tough 6020 Lens Replacement: 手順 11、 1の画像 1
    • Gently lift Lens compartment out of device.
  12. Olympus Stylus Tough 6020 Lens Replacement: 手順 12、 1の画像 1
    • From top view, unscrew 3 screws
    • Do not worry about the screw on top of the 2 screws.
  13. Olympus Stylus Tough 6020 Lens Replacement: 手順 13、 2の画像 1 Olympus Stylus Tough 6020 Lens Replacement: 手順 13、 2の画像 2
    • Lens comes off
終わりに
作成者
4人の作成者と共同で作成されました。
Violeta
メンバー登録日: 04/08/15
101 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 2-6, Matresse Spring 2015 Eastern Washington University, Team 2-6, Matresse Spring 2015人のメンバー
EWU-MATRESSE-S15S2G6
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 19
今までの合計 535
