メインコンテンツにスキップ
Olympus Stylus 760 LCD Screen Replacement
必要な工具と部品
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: 手順 1、 1の画像 1
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: 手順 2、 1の画像 1
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: 手順 3、 1の画像 1
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: 手順 4、 1の画像 1
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: 手順 5、 1の画像 1
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: 手順 6、 1の画像 1
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: 手順 7、 3の画像 1 Olympus Stylus 760 LCD Screen Replacement: 手順 7、 3の画像 2 Olympus Stylus 760 LCD Screen Replacement: 手順 7、 3の画像 3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: 手順 8、 2の画像 1 Olympus Stylus 760 LCD Screen Replacement: 手順 8、 2の画像 2
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: 手順 9、 3の画像 1 Olympus Stylus 760 LCD Screen Replacement: 手順 9、 3の画像 2 Olympus Stylus 760 LCD Screen Replacement: 手順 9、 3の画像 3
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: 手順 10、 1の画像 1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: 手順 11、 2の画像 1 Olympus Stylus 760 LCD Screen Replacement: 手順 11、 2の画像 2
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: 手順 12、 2の画像 1 Olympus Stylus 760 LCD Screen Replacement: 手順 12、 2の画像 2
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: 手順 13、 1の画像 1
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Ryan Cosgrove
メンバー登録日: 02/10/12
39 ポイント
1ガイドが承認済み
チーム
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012人のメンバー
JMU-KLEIN-S12S3G3
4 メンバー
7のガイドは作成済み
コメント 1 件
from where i can get repaired u760 camera
tahir zafar - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,505
