はじめに
If your Olympus Stylus (1030 SW) camera has multiple damage parts, such as both front and rear cases, flash assembly, the AV port, or the batter door, you can use this guide to replace these parts.
Using this guide you will find how to replace damage products of the Olympus Stylus (130 SW). Before using our guide you should make sure the camera is powered off, and inspect for any damaged or missing pieces.
必要な工具と部品
Start by removing the front case of the Olympus Stylus 1030 SW.
Use a Phillips #00 screwdriver to unscrew the three screws.
Once all three screws are removed, take your hand to remove the front case from the camera. You will lift until it is fully off.
