Using the iFixit Opening Tool, pry off the plastic part of the lens.
Using the T6 Torx screwdriver, unscrew the three screws.
Using the Phillips #00 screwdriver, unscrew the three screws.
Carefully swivel the metal cover out towards you.
Using tweezers, remove the metal washer.
On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
Take out the speaker plate.
Open the multi-connector cover and slide off the side panel.
Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
On the bottom side of the camera, unscrew the two screws.
On the front of the camera, unscrew the two screws shown.
Gently pull on the side until the camera is separated from the back panel.
Remove the shutter and power button.
Release the top holding using a spudger.
Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
Unscrew the two screws found on the left side of the screen using the PH#00 head.
Peel off the gel tape using tweezers.
Unscrew the five 0.6 mm screws using the Phillips #00 screwdriver.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
