はじめに
If you’re looking to replace a part of your Olympus Stylus 1030 SW Camera, you will most likely need to disassemble it first. This guide will help you accomplish that. Don’t worry, no special skills are required.
Before you begin disassembling, be sure to remove the SD card and the battery from the camera.
必要な工具と部品
Using the iFixit Opening Tool, pry off the plastic part of the lens.
Using the T6 Torx screwdriver, unscrew the three screws.
もう少しです!
終わりに
