メインコンテンツにスキップ
Olympus OM-D E-M10 Mark II Screen Replacement
必要な工具と部品
  1. Olympus OM-D E-M10 Mark II Screen Replacement, Screen: 手順 1、 2の画像 1 Olympus OM-D E-M10 Mark II Screen Replacement, Screen: 手順 1、 2の画像 2
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II Screen Replacement: 手順 2、 1の画像 1
    • Extend out the screen so you can reach the screws. Remove the a total of four screws using a Phillips #00 at the top and the back of the screen.
    • This step has two types of screws. (2x) 3.5 mm on the top, (2x) 1.7 mm on the back.
  3. Olympus OM-D E-M10 Mark II Screen Replacement: 手順 3、 1の画像 1
    • Pull the screen away from the base of the camera. Then disconnect the cable connectors from the circuit board. Be sure to remove the smaller circuit board with care.
  4. Olympus OM-D E-M10 Mark II Screen Replacement: 手順 4、 1の画像 1
    • Separate the screen from the camera. Now you are able to install your replacement screen
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Connor Langguth
メンバー登録日: 09/03/19
346 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G5, Hovde Fall 2019 IUPUI, Team S1-G5, Hovde Fall 2019人のメンバー
IUPUI-HOVDE-F19S1G5
3 メンバー
5のガイドは作成済み
4 件のコメント
Hi, do you know if the LCD screen from the Mark II is the exact same as the Mark III? I see replacements for the Mark II being sold, but they don’t say whether they’re compatible.
Solomon Krause-Imlach - 返信
Hey Solomon I am experiencing the same issue. Did you find out if they are exactly the same?? My LCD screen no longer functions and all I come across online is the Mark II LCD's.
Zacharia Gupta -
Hi, do you know where I can buy the screen?
Thanks
Lorenzo
Lorenzo Zaccarini - 返信
If you order only panel like me, theres few wery scary parts more. You have to remove couple pcb's, trying get connectors back in and you definetly need elastic glue for glueing screen back.
Mikko Hyvärinen - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 45
過去 30 日: 259
今までの合計 10,037
