メインコンテンツにスキップ
Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement
必要な工具と部品
  1. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement, HDMI and Multi-connector Cover: 手順 1、 1の画像 1
    • There are three different types and lengths of screws used to hold the bottom plate of the camera. Make proper note of each screws original position during your disassembly.
    • Using the PH00 Phillips-head screwdriver, unscrew the two 1/3 inch screws with silver threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/3 inch screws with blue threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/2 inch screws with silver threads from the the bottom of the camera.
  2. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 手順 2、 1の画像 1
    • After removing all of the screws, remove the bottom plate from the camera to continue.
  3. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 手順 3、 2の画像 1 Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 手順 3、 2の画像 2
    • Continuing to use the size PH00 Phillips-head screwdriver, remove the two 3/5 inch screws revealed after removing the bottom plate of the camera.
  4. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 手順 4、 1の画像 1
    • Open the HDMI connector door and continue to use the PH00 Phillips-head screwdriver to remove the 3/10 inch screw located underneath the door.
  5. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 手順 5、 1の画像 1
    • Proper removal of all 11 screws listed in the steps above from the camera gives the camera the ability to be opened slightly and allows for the door to be lifted off of the hooks holding it in place within the camera.
終わりに
To add your new HDMI connector door, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Allen Anjal
メンバー登録日: 09/27/16
341 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S5G6
4 メンバー
10のガイドは作成済み
コメント 1 件
so, where can I buy the port cover or door for the OMD-em10 mark2? Thanks
Raffy Martinez - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 39
今までの合計 2,904
