メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Olympus FE-210 Lens Assembly Replacement
必要な工具と部品
  1. Olympus FE-210 Lens Assembly Replacement, Battery: 手順 1、 2の画像 1 Olympus FE-210 Lens Assembly Replacement, Battery: 手順 1、 2の画像 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
    FixBotに聞いてみる
    コメントを追加
  2. Olympus FE-210 Lens Assembly Replacement: 手順 2、 2の画像 1 Olympus FE-210 Lens Assembly Replacement: 手順 2、 2の画像 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
    FixBotに聞いてみる
    コメントを追加
  3. Olympus FE-210 Lens Assembly Replacement, Front Casing: 手順 3、 3の画像 1 Olympus FE-210 Lens Assembly Replacement, Front Casing: 手順 3、 3の画像 2 Olympus FE-210 Lens Assembly Replacement, Front Casing: 手順 3、 3の画像 3
    • Remove the seven screws holding the front case in place, with a Phillips #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
    FixBotに聞いてみる
    コメントを追加
  4. Olympus FE-210 Lens Assembly Replacement: 手順 4、 3の画像 1 Olympus FE-210 Lens Assembly Replacement: 手順 4、 3の画像 2 Olympus FE-210 Lens Assembly Replacement: 手順 4、 3の画像 3
    • Insert an opening tool or spudger into the seam between the front case and body of the camera to release the clips holding it together.
    • These three places are located:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
    FixBotに聞いてみる
    コメントを追加
  5. Olympus FE-210 Lens Assembly Replacement, Rear Casing: 手順 5、 1の画像 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. Olympus FE-210 Lens Assembly Replacement: 手順 6、 3の画像 1 Olympus FE-210 Lens Assembly Replacement: 手順 6、 3の画像 2 Olympus FE-210 Lens Assembly Replacement: 手順 6、 3の画像 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
    FixBotに聞いてみる
    コメントを追加
  7. Olympus FE-210 Lens Assembly Replacement, Motherboard: 手順 7、 2の画像 1 Olympus FE-210 Lens Assembly Replacement, Motherboard: 手順 7、 2の画像 2
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
    FixBotに聞いてみる
    コメントを追加
  8. Olympus FE-210 Lens Assembly Replacement: 手順 8、 2の画像 1 Olympus FE-210 Lens Assembly Replacement: 手順 8、 2の画像 2
    • Remove the seven 2.7 mm using a #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  9. Olympus FE-210 Lens Assembly Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
    FixBotに聞いてみる
    コメントを追加
  10. Olympus FE-210 Lens Assembly Replacement: 手順 10、 1の画像 1
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
    FixBotに聞いてみる
    コメントを追加
  11. Olympus FE-210 Lens Assembly Replacement: 手順 11、 2の画像 1 Olympus FE-210 Lens Assembly Replacement: 手順 11、 2の画像 2
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
    FixBotに聞いてみる
    コメントを追加
  12. Olympus FE-210 Lens Assembly Replacement: 手順 12、 1の画像 1
    • Remove the motherboard from the camera casing.
    FixBotに聞いてみる
    コメントを追加
  13. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: 手順 13、 1の画像 1
    • Remove the three 3.6 mm screws using a #00 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  14. Olympus FE-210 Lens Assembly Replacement: 手順 14、 2の画像 1 Olympus FE-210 Lens Assembly Replacement: 手順 14、 2の画像 2
    • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
6人の作成者と共同で作成されました。
Matt
メンバー登録日: 01/25/11
826 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G36
3 メンバー
14のガイドは作成済み
1件のガイドコメント
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 59
今までの合計 7,269
