メインコンテンツにスキップ
はじめに
Before removing the LCD screen you must first remove the rear camera casing.
パーツ
パーツは指定されていません。
  1. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries.
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. The batteries will slide right out. When putting new batteries in, make sure they are pointing the right direction.
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Remove the 7 screws holding the front case in place, with a #00 screwdriver. Six screws are 3.6 mm. The seventh screw is 3.2 mm.
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  5. Pulling the front case off, requires applying enough strength in the right areas. The front case snaps into place in three places: At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  6. Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  7. Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard. Lift the white latch using a fingernail or a spudger. Pull the cord from its connector.
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  8. Remove the two 2.7 mm screws using a #00 screwdriver. After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
    • Remove the two 2.7 mm screws using a #00 screwdriver.
    • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  9. Using a spudger, lift the latch on the connector. Remove the ribbon cord from its connector. Remove the LCD from the rest of the camera.
    • Using a spudger, lift the latch on the connector.
    • Remove the ribbon cord from its connector.
    • Remove the LCD from the rest of the camera.
まとめ
ある他の人がこのガイドを完成しました。
Matt
メンバー登録日: 2011年01月25日
781 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S4G36
3 メンバー
7のガイドは作成済み
コメント1件
Now need source for replacement screen thank you
Emile Crotteau - 返信
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 4,728
