はじめに
This guide is designed to teach an ifixit user to replace the sensor lens for an Olympus E-PL1 camera.
必要な工具と部品
Push the gray tab down, using a spudger if necessary, and the battery will come out.
There are a total of six screws that must be removed using the the #000 Philips screwdriver.
As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
Using a spudger, remove the ribbon cables by pushing the black tab back and gently pulling the cable out.
Do this process for the two ribbon cables shown in the third photo.
Now you can lift out the sensor assembly. The following steps will explain how to lift it out.
First, sightly lift the bottom half following the direction of the arrow.
Second, lift the top left up side up. It may be a little stuck so you will have to wiggle it out.
Finally, pull the entire assembly towards the bottom and away from the case.
Remove the 3 screws surrounding the sensor lens with a #000 Phillips screwdriver.
3 の人々がこのガイドを完成させました。
コメント 1 件
Hello. Is it possible to remove glass from sensor without damaging microwires? I want to debayer sensor.
