メインコンテンツにスキップ
Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement
必要な工具と部品
  1. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement, Front Case: 手順 1、 1の画像 1
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 2、 1の画像 1
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 3、 1の画像 1
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 4、 1の画像 1
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 5、 1の画像 1
    • Now you should be able to remove the front case easily using your hand.
  6. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement, Shutter + ON/OFF Buttons Plastic Holder: 手順 6、 1の画像 1
    • Use the PH000 to remove the 7mm screw on the upper right corner of the device.
  7. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 7、 1の画像 1
    • Use the PH000 screwdriver to remove the 5 mm screw located on the top left side of the device.
  8. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 8、 1の画像 1
    • Use the PH000 screwdriver to remove the 3mm screw shown on the picture.
  9. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 9、 1の画像 1
    • Using the PH000, remove the 3mm screw shown on the picture.
  10. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 10、 1の画像 1
    • Use the PH000 screwdriver to remove the 4mm located below the ON/OFF button.
  11. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 手順 11、 1の画像 1
    • Using your hand, remove the plastic button holder containing the shutter and ON/OFF buttons. The buttons and metal springs under it are now unlocked.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Natalia Morales
メンバー登録日: 10/11/16
675 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 1-6, Leahy Fall 2016 USF Tampa, Team 1-6, Leahy Fall 2016人のメンバー
USFT-LEAHY-F16S1G6
3 メンバー
10のガイドは作成済み
コメント 1 件
Thanks for the post. Do you know where to buy new switches?
Richard Chesher - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 33
今までの合計 1,676
