はじめに
This guide requires you to handle sharp metal objects. Proceed with caution. To avoid misplacing the screws hold them in place with masking tape. Make sure your hands are clean and dry before they come in contact with the internal parts of the camera.
必要な工具と部品
Use the PH000 screwdriver to remove both 2mm screws holding the gasket of the HDMI port door. Remove the rubber gasket.
もう少しです!
終わりに
