メインコンテンツにスキップ
Olympus D590 Retainer Clip Replacement
必要な工具と部品
  1. Olympus D590 Retainer Clip Replacement, Face Plate: 手順 1、 1の画像 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Retainer Clip Replacement: 手順 2、 1の画像 1
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Retainer Clip Replacement: 手順 3、 1の画像 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Retainer Clip Replacement: 手順 4、 1の画像 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Retainer Clip Replacement: 手順 5、 1の画像 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Retainer Clip Replacement: 手順 6、 1の画像 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Retainer Clip Replacement: 手順 7、 1の画像 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Retainer Clip Replacement, Retainer Clip: 手順 8、 1の画像 1
    • Orient the camera as shown, with the bottom facing up.
    • Open the retainer clip, by using your finger to push down and slide to the left.
    • The clip should pop open.
  9. Olympus D590 Retainer Clip Replacement: 手順 9、 1の画像 1
    • Hold the retainer clip down (without re-latching it).
    • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
  10. Olympus D590 Retainer Clip Replacement: 手順 10、 1の画像 1
    • Use tweezers to continue to remove the pin.
  11. Olympus D590 Retainer Clip Replacement: 手順 11、 1の画像 1
    • When it feels loose, pull the pin all the way out with your fingers.
  12. Olympus D590 Retainer Clip Replacement: 手順 12、 1の画像 1
    • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
終わりに
作成者
4人の作成者と共同で作成されました。
Katie
メンバー登録日: 04/15/10
31 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010人のメンバー
CPSU-REGAN-S10S28G23
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,140
