メインコンテンツにスキップ
はじめに
The LED indicates the status of the camera and blinks to show activity. Despite the simple nature of the part, the process to repair is quite difficult. Replacement requires soldering, and diving deep into the inner workings of the camera.
パーツ
パーツは指定されていません。
  1. Remove the 4 mm screw directly to the right of the viewfinder on the back side of the camera using a Phillips #00 screwdriver. Remove the five 3 mm screws from the bottom of the camera using a Phillips #00 screwdriver. Remove the 3 mm screw from the right side panel using a Phillips #00 screwdriver.
    • Remove the 4 mm screw directly to the right of the viewfinder on the back side of the camera using a Phillips #00 screwdriver.
    • Remove the five 3 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
    • Remove the 3 mm screw from the right side panel using a Phillips #00 screwdriver.
    • Remove the two 2 mm screws from the left side panel using a Phillips #00 screwdriver.
  2. Rock the two ribbon cables gently out of their sockets. For more on disconnecting ribbon cables, look here. Grasp and pull the white cable out of its clip with metal tweezers.
    • Rock the two ribbon cables gently out of their sockets. For more on disconnecting ribbon cables, look here.
    • Grasp and pull the white cable out of its clip with metal tweezers.
    • Remove the back panel completely.
  3. Peel off the black plastic sheets.
    • Peel off the black plastic sheets.
    • Remove the two 3 mm screws holding the motherboard in place using the Phillips #00 screwdriver.
  4. Remove one ribbon cable directly below the viewfinder. Detach the white plastic clip from its socket with a pair of tweezers.
    • Remove one ribbon cable directly below the viewfinder.
    • Detach the white plastic clip from its socket with a pair of tweezers.
    • Disconnect the ribbon cable from the center of the board, near the central hole.
    • Disconnect three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and two are on the underside.
    • For more information on disconnecting ribbon cables, look here.
  5. Remove the single 3 mm ground screw attached to the right side of the camera body using the Phillips #00 screwdriver.
    • Remove the single 3 mm ground screw attached to the right side of the camera body using the Phillips #00 screwdriver.
  6. Use the soldering iron to desolder the connections from the motherboard.
    • Use the soldering iron to desolder the connections from the motherboard.
    • For more information on desoldering, look here.
    • Don't attempt to desolder the joints without previous knowledge of soldering.
    • When soldering, avoid touching any of the other components with the soldering iron by accident. You may damage them.
  7. Remove the motherboard from the camera.
    • Remove the motherboard from the camera.
  8. Now we remove the bulk of the cameras components from the front of the case. Unscrew the 2-3mm Screws from the right side of the casing
    • Now we remove the bulk of the cameras components from the front of the case.
    • Unscrew the 2-3mm Screws from the right side of the casing
    • Pop the flash up, to get access to the two body screws underneath.
    • Undo the 2-3mm screws
  9. Gently pull on the battery casing and the A/V ports to remove the connected components Remove the small ribbon cable, from the right side of the casing Remove the small ribbon cable, from the right side of the casing
    • Gently pull on the battery casing and the A/V ports to remove the connected components
    • Remove the small ribbon cable, from the right side of the casing
  10. Lastly we remove the LED circuit board Undo 1-3mm screw
    • Lastly we remove the LED circuit board
    • Undo 1-3mm screw
    • We can replace the circuit board or the colored plastic insert
終わりに
Mason Morgan
メンバー登録日: 2011年04月05日
115 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 12-33, Maness Spring 2011 Cal Poly, Team 12-33, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G33
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 2,119
