この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The sensor is what captures the image the user takes. It is the most important part of the camera. The image sensor is deep inside the camera, requiring multiple steps and soldering to reach the sensor.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
Remove the two 2mm screws from the left side panel.
Remove the single 3mm screw from the right side panel.
Remove the five 3mm screws from the bottom of the camera.
Remove the ribbon cable directly below the viewfinder.
Detach the white plastic clip from its socket with a pair of tweezers.
Disconnect the ribbon cable from the center of the board, near the central hole.
Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
The lens does not have to be removed from the body to access or remove the image sensor
Remove the 3-3mm screws holding the sensor in place.
