はじめに
The sensor is what captures the image the user takes. It is the most important part of the camera. The image sensor is deep inside the camera, requiring multiple steps and soldering to reach the sensor.
ツール
パーツ
パーツは指定されていません。
Remove all nine screws that hold the back plate in place with the Phillips #00 Screwdriver. The screws are located on the back, the base (bottom), right, and left sides of the camera.
Unscrew the 4mm screw that is directly to the right of the viewfinder on the back side of the camera.
On the base (bottom):
Unscrew the 3mm screw in the top left corner.
Unscrew all four 3mm screws under the battery cover.
Unscrew the 3mm screw on the right side panel.
Unscrew the two 2mm screws on the left side panel.
Gently separate the seven ribbon cables from the motherboard. For more information on disconnecting ribbon cables, look here.
There is one directly below the viewfinder (Image 1, blue).
Two are on the base of the camera (Image 2, blue).
There are three at the top right of the motherboard, near the selector wheel. One is on the top of the board, and two are on the underside (Image 1, green).
The final one is in the center of the board, near the central hole (Image 1, yellow).
Remove the two white plastic clips from their sockets with metal tweezers. One is on the base of the board (Image 2, red) and the other is on the surface (Image 1, red).
The lens does not have to be removed from the body to access or remove the image sensor
Remove the 3-3mm screws holding the sensor in place.
