はじめに
The X7R Marauder from Olight is a great flashlight. Unfortunately, the batteries are permanently installed and, according to the manufacturer, cannot be replaced by the user.
If your batteries go bad after the warranty has expired, you can use the following steps to replace the batteries in your Olight 7XR flashlight.
必要な工具と部品
The three screws on the side can be loosened by a 0.9mm Allen key.
The cover can then be removed.
Reverse the steps to reassemble your device.
2 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Andrew Sさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
2 件のコメント
what size allen key?
what size are the batteries?
ben senise - 返信
The allen key size is H0.9mm
The battery size is 18650.
Andrew S -
