メインコンテンツにスキップ
Oculus Rift Development Kit 2 Headset Motherboard Replacement
必要な工具と部品
  1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 手順 1、 3の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 手順 1、 3の画像 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 手順 1、 3の画像 3
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 2、 3の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 2、 3の画像 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 2、 3の画像 3
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 3、 2の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 3、 2の画像 2
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: 手順 4、 2の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: 手順 4、 2の画像 2
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 6、 1の画像 1
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 7、 2の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 7、 2の画像 2
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 8、 2の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 8、 2の画像 2
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 9、 3の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 9、 3の画像 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 9、 3の画像 3
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 10、 1の画像 1
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 11、 3の画像 1 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 11、 3の画像 2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 手順 11、 3の画像 3
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
終わりに
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Adam
メンバー登録日: 01/20/15
661 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-5, Maness Winter 2015 Cal Poly, Team 18-5, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S18G5
4 メンバー
6のガイドは作成済み
1件のガイドコメント
hi.
you know where possible buy the new motherboard?
Szatmari Attila - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 2,649
