メインコンテンツにスキップ
OPPO N1 Headphone Jack and Speaker Cover Replacement
必要な工具と部品
  1. OPPO N1 Headphone Jack and Speaker Cover Replacement, Rear Case: 手順 1、 1の画像 1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 2、 2の画像 1 OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 2、 2の画像 2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: 手順 3、 2の画像 1 OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: 手順 3、 2の画像 2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 5、 1の画像 1
    • Remove the black plate with your fingers.
  6. OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 6、 3の画像 1 OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 6、 3の画像 2 OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 6、 3の画像 3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 7、 2の画像 1 OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 7、 2の画像 2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Headphone Jack and Speaker Cover Replacement, Headphone Jack and Speaker Cover: 手順 8、 1の画像 1
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
  9. OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 9、 2の画像 1 OPPO N1 Headphone Jack and Speaker Cover Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers or your fingers to remove the plastic cover.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Joshua Stone
メンバー登録日: 09/26/14
1,064 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G5
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 1,474
