この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will show you how to access the camera on your OLPC XO 4.0 Touch. The camera records video into your laptop.
必要な工具と部品
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Unplug the ribbon cable from the connector on the underside of the motherboard.
Pull the camera away from the motherboard to remove it.
