メインコンテンツにスキップ
OLPC XO-4 Touch Antenna Replacement
必要な工具と部品
  1. OLPC XO-4 Touch Antenna Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Antenna Replacement: 手順 2、 2の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 2、 2の画像 2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Antenna Replacement: 手順 3、 2の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 3、 2の画像 2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Antenna Replacement, Screen Frame: 手順 4、 3の画像 1 OLPC XO-4 Touch Antenna Replacement, Screen Frame: 手順 4、 3の画像 2 OLPC XO-4 Touch Antenna Replacement, Screen Frame: 手順 4、 3の画像 3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Antenna Replacement: 手順 5、 3の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 5、 3の画像 2 OLPC XO-4 Touch Antenna Replacement: 手順 5、 3の画像 3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Antenna Replacement: 手順 6、 1の画像 1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Antenna Replacement: 手順 7、 2の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 7、 2の画像 2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Antenna Replacement, Screen: 手順 8、 1の画像 1
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Antenna Replacement: 手順 9、 2の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 9、 2の画像 2
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Antenna Replacement: 手順 10、 3の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 10、 3の画像 2 OLPC XO-4 Touch Antenna Replacement: 手順 10、 3の画像 3
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Antenna Replacement: 手順 11、 1の画像 1
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Antenna Replacement, Back Cover: 手順 12、 1の画像 1
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Antenna Replacement: 手順 13、 2の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 13、 2の画像 2
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Antenna Replacement, Antenna: 手順 14、 3の画像 1 OLPC XO-4 Touch Antenna Replacement, Antenna: 手順 14、 3の画像 2 OLPC XO-4 Touch Antenna Replacement, Antenna: 手順 14、 3の画像 3
    • When pulling out connectors, make sure to hold the metal connector instead of the wire.
    • Gently unplug the two connectors by pulling them away from the motherboard.
  15. OLPC XO-4 Touch Antenna Replacement: 手順 15、 3の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 15、 3の画像 2 OLPC XO-4 Touch Antenna Replacement: 手順 15、 3の画像 3
    • Unscrew the four black 4mm Phillips #1 screws holding the metal cover on.
    • Remove the metal cover by gently lifting it out of the laptop.
  16. OLPC XO-4 Touch Antenna Replacement: 手順 16、 2の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 16、 2の画像 2
    • Flip the top part of the laptop over so that you are looking at the front.
    • Unscrew the two 12.7mm Phillips #1 screws on each antenna ear clamp.
    • Remove the two outer clamps.
  17. OLPC XO-4 Touch Antenna Replacement: 手順 17、 3の画像 1 OLPC XO-4 Touch Antenna Replacement: 手順 17、 3の画像 2 OLPC XO-4 Touch Antenna Replacement: 手順 17、 3の画像 3
    • Remove the antenna wires from the black tabs.
    • On the front side of the laptop, carefully pull the wire through the hole and out.
    • Remove the antenna from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Matthew Smith
メンバー登録日: 01/25/13
23 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013人のメンバー
CPSU-AMIDO-W13S3G29
4 メンバー
20のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 452
