はじめに
The extending antennas at the top of the OLPC are crucial to receiving a wireless signal. Use this guide to replace faulty antennas and regain connectivity.
パーツ
パーツは必要ありません。
  1. Place the laptop upside down with the handle away from you.
    • Place the laptop upside down with the handle away from you.
  2. Slide the tabs out, towards the green edges,  to show the open lock symbol.
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. Lift the middle of the battery to remove it. Lift the middle of the battery to remove it. Lift the middle of the battery to remove it.
    • Lift the middle of the battery to remove it.
  4. Turn the laptop so it is resting on its bottom. Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop. Rotate the top half of the laptop about 90 degrees.
    • Turn the laptop so it is resting on its bottom.
    • Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
    • Rotate the top half of the laptop about 90 degrees.
  5. Turn the laptop upside down, so you can see the screws on the bottom of the top half. Remove the two 4mm screws with a Phillips #1 screwdriver.
    • Turn the laptop upside down, so you can see the screws on the bottom of the top half.
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
    • Rotate the top half 180 degrees.
  6. Rotate the top of the laptop 90 degrees, so that it is facing you again.
    • Rotate the top of the laptop 90 degrees, so that it is facing you again.
    • Slide the green pieces off the device. They should come off easily.
  7. Pull down on the white screen cover. It does not require much force. Remove the screen cover. The game pad on the left sometimes falls during this step.
    • Pull down on the white screen cover. It does not require much force.
    • Remove the screen cover.
    • The game pad on the left sometimes falls during this step.
  8. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  9. Unscrew the four 7.62mm Phillips #1 screws on either side of the screen. The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
    • Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
    • The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
    • Move the screen down a little to expose the ribbon cables.
  10. Flip up the tab right under the middle top of the screen. Pull the black ribbon cable out of the socket. Pull the black ribbon cable out of the socket.
    • Flip up the tab right under the middle top of the screen.
    • Pull the black ribbon cable out of the socket.
  11. Flip up the smaller tab under the left side of the screen. Remove the small cable to separate the screen from the rest of the laptop.
    • Flip up the smaller tab under the left side of the screen.
    • Remove the small cable to separate the screen from the rest of the laptop.
    • Gently remove the screen.
  12. Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
    • Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
  13. Close the lid and rotate the device 180°. Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
    • Close the lid and rotate the device 180°.
    • Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
  14. Remove the five 4mm Phillips #1 screws securing the EMI shield to the motherboard. Gently lift up and remove the EMI shield.
    • Remove the five 4mm Phillips #1 screws securing the EMI shield to the motherboard.
    • Gently lift up and remove the EMI shield.
  15. Gently remove the two antenna cables by lightly pulling the cable connectors up.
    • Gently remove the two antenna cables by lightly pulling the cable connectors up.
  16. Remove the two 5mm Phillips #1 screws holding the wireless card to the motherboard. The wireless card will pop up at an angle.
    • Remove the two 5mm Phillips #1 screws holding the wireless card to the motherboard.
    • The wireless card will pop up at an angle.
  17. Remove the wireless card by gently lifting it out of the socket.
    • Remove the wireless card by gently lifting it out of the socket.
  18. Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets. The motherboard is still attached to the case by a microphone cable. Do not remove the motherboard or you will damage the cable. The motherboard is still attached to the case by a microphone cable. Do not remove the motherboard or you will damage the cable.
    • Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
    • The motherboard is still attached to the case by a microphone cable. Do not remove the motherboard or you will damage the cable.
  19. Rotate the device 180° and open the lid.
    • Rotate the device 180° and open the lid.
    • Disconnect the microphone cable by pulling its connector straight out of its socket on the motherboard.
  20. Close the lid and rotate the device 180°. Lift the left edge of the motherboard and remove it from the case. Make sure that the microphone and headphone jack don't catch on the case as you are removing the motherboard.
    • Lift the left edge of the motherboard and remove it from the case.
    • Make sure that the microphone and headphone jack don't catch on the case as you are removing the motherboard.
  21. Open the lid, rotate it 180° degrees, and close it again. Lift the antennas and their hinges out of the case. Pull the antenna away from the device to pull the cable through the channels it's routed through.
    • Open the lid, rotate it 180° degrees, and close it again.
    • Lift the antennas and their hinges out of the case.
    • Pull the antenna away from the device to pull the cable through the channels it's routed through.
まとめ
Wei Xia
メンバー登録日: 2013年01月25日
518 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 3-28, Amido Winter 2013 Cal Poly, Team 3-28, Amido Winter 2013人のメンバー
CPSU-AMIDO-W13S3G28
3 メンバー
5のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 217
