メインコンテンツにスキップ
OBSOLETE - How to Remove a stuck game from an Xbox 360
必要な工具と部品
  1. OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 手順 1、 3の画像 1 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 手順 1、 3の画像 2 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 手順 1、 3の画像 3
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. OBSOLETE - How to Remove a stuck game from an Xbox 360, Find the emergency eject hole: 手順 2、 1の画像 1
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
  3. OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 手順 3、 3の画像 1 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 手順 3、 3の画像 2 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 手順 3、 3の画像 3
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
終わりに
19 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Nick
メンバー登録日: 11/10/09
93,519 ポイント
59のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
327 メンバー
1,699のガイドは作成済み
2 件のコメント
will this work for elite 250 gug
duangphetv - 返信
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 35
今までの合計 31,670
