メインコンテンツにスキップ
Nvidia Shield Tablet Speaker Replacement
必要な工具と部品
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: 手順 1、 2の画像 1 Nvidia Shield Tablet Speaker Replacement, Rear Case: 手順 1、 2の画像 2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: 手順 2、 3の画像 1 Nvidia Shield Tablet Speaker Replacement: 手順 2、 3の画像 2 Nvidia Shield Tablet Speaker Replacement: 手順 2、 3の画像 3
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: 手順 3、 2の画像 1 Nvidia Shield Tablet Speaker Replacement: 手順 3、 2の画像 2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: 手順 4、 1の画像 1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: 手順 5、 1の画像 1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: 手順 6、 3の画像 1 Nvidia Shield Tablet Speaker Replacement: 手順 6、 3の画像 2 Nvidia Shield Tablet Speaker Replacement: 手順 6、 3の画像 3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: 手順 7、 2の画像 1 Nvidia Shield Tablet Speaker Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    $7.95
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Molly Bauer
メンバー登録日: 08/27/15
1,478 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S2G2
3 メンバー
11のガイドは作成済み
1件のガイドコメント
This didn't work
Riley Schork - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 2,794
