はじめに
The case of any device is always the first line of defense against any kind of external damage. The Shield Tablet in particular is known to be susceptible to casing cracks, specifically at the corners. This guide will show you the step-by-step instructions required to replace your cracked case.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Set the tablet so the buttons, microSD, and stylus port are facing you.
Open the microSD slot.
Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
5 の人々がこのガイドを完成させました。
コメント 1 件
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
